RCU Forums - View Single Post - MDS 2.18 And A Cline Regulating Pump?
Old 11-23-2003 | 09:19 PM
Crazy_Cplanes
Default MDS 2.18 And A Cline Regulating Pump?
Is there anybody out there running a Cline regulating pump on this engine and if so, is there any problems or anything that I should be aware of before I make this purchase. I was planning on running large fuel line but I noticed on the cline web site all you need to run is medium fuel line. Should I run medium line or should I run large on this size of a motor? I was also, planning on running a large clunk with large brass coming out of the fuel tank, Do I still need to do this or with running the Cline regulating pump I only need Medium line and small brass? Also, I was wondering where you mounted the Cline pump if it was inbetween the carb inlet and the remote needle or is it before the remote needle? And how did you mount the pump is it soft mounted or is it hard mounted to the engine some how. Any help on this subject would be appreiaciated.
