RE: Capiche 50
im not a big fan of hitecs either. At the weekend i bought a pair of Hitec Hs-255 mighty minis like sprinks got for the ailerons. Took them home tested them. If you held it lightly at full travel then let goit jammedand had to turn the radio off and on again for it to unjam[&:] tried the other, it also did it[&:] after a while, it stopped doing it and they both work fine now. Seeing as this could happen in flight i will take them back when i get a chance.
i did a bit of sanding at the WE and also designed my probable colour scheme on a three view.
may post this evening
