pull-pull problem
I try to install a pull-pull on a 31% AW edge540 arf.
measured everything, and the cables cross the fuse side lines right in fron of the hor.stab.
the thing is, there is nothing there at the cable exit point but the covers, no balsa no nothing.
can i just make a small hole in the cover, add a plastic "pushrod exit" things and glue it to the cover as an exit
or do I have to open the covers and install a good balsa block for a guide to go through? really don't want to cut the covers...
does that cable exit location makes sence?
