RCU Forums - View Single Post - Building the Mick Reeves Hawker Hunter
Old 11-24-2003 | 08:42 PM
  #38
Gordon Mc
Default RE: Building the Mick Reeves <span class=
I have also installed the gear and the associated formers in the fuselage now. This took a little thought, as the nose gear retract must be fitted from the bottom, yet will not fit through the openings for the gear doors. In the end, I elected to cut the gear doors exactly to their scale size, then cut a wider section out on either side of the rear gear door. The additional cut-outs will be removable and mounted via some poly-ply screws and tabs. (Pics later)
Here are a couple of pics of the model sitting on its gear for the first time:
ID:	77277   Click image for larger version
