RCU Forums - View Single Post - Tango Assembly
Old 11-25-2003 | 11:06 AM
  #40
lov2flyrc's Avatar
lov2flyrc
My Feedback: (24)
Default RE: Tango Assembly
Kim,
I did notice on mine the first flight that I had some slight pitch change toward the canopy at high power. One washer under the rear mounting lug bolt corrected the thust line. You may need to add a washer (perhaps two with the extra drag of the fixed gear). Trim the plane at a low thrust setting then add full power and see if the plane tends to climb or sink slightly.
Sean, I'll call you later
Todd
