RE: Precision Eagle 4.2 Performance Question
Some of the Precision Eagle engines had the bottom of the piston skirt cut off on one side about 1/8" to get more intake duration...If yours is one of those the piston skirt doesn't cover up the intake port early enough to keep some of the charge from coming back out the carb at lower rpms......You might try a velocity stack with a 45 degree angle facing forward....
