RE: pull-pull problem
Mazlat, I have used the red Sullivan outer sheath to exit the covering and a piece of the inner yellow rod as a sliding bearing in the red outer sheath. Use Kevlar pull-pull cable and tack it to the yellow inner tubing. This way there will be a near frictionless sliding fit that will never cut the covering and looks good.
Ken
