RCU Forums - View Single Post - engine has little response when in a hover
Old 05-13-2002 | 10:04 PM
SNAFU
Default BME
What prop are you using I have the menz ultra on mine. The engine deffinetly does not fit the cowl. I made a custom one took three days but looks pretty good. I also had to shoten the cowl to keep from adding alot of weight to the tail. I have been flying it for a year now use good glue. All around the engine box and frame I used an epoxy glue that mix's two parts into one by way of a mixing nozzel. I use to fly turbines and this stuff won't come apart. I can tell you were to buy it if you want Bob Violet sells it under aeropoxy. Grainger sells it for less. I will richen the low end and let you know.
