RCU Forums - View Single Post - A DROP BOX ON THE NEXS*T*A*R???
Old 11-28-2003 | 11:08 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: A DROP BOX ON THE NEXS*T*A*R???
A lot depends on what you want to drop.
If it's a single item, like a paratrooper, you could just hold it in place under the plane with a rubber band that will release via a push rod.
If you want to drop multiple items, like candy, you would need to build a box (internal or external). the door could be operated in a similar fashion, or do a proper "Bomb Bay" type of door.
ID:	78190   Click image for larger version
