RCU Forums - View Single Post - Help I'm confused!!!!!!
Old 11-28-2003 | 04:36 PM
Gotta_Fly
Default Help I'm confused!!!!!!
I don't know if I'm in the right forum or not but dual rates and rates in general are in 3D,, Here is the deal, also you might want to read this a few times cause when I read it back it confused me, anyway I have put together about 11 ARF's since I started this hobby close to a year ago, Well right now I'm putting together a Waco .60 bi-wing plane and when it came to the part about setting the rates it was talking about Full rate and dual rate what is the defferents?? also it said to set my aileron control throw at 3/8" up and down on full rate and 5/8 up and down on dual rate so what does that mean ??and what really confused me was when I got to the Rudder and Elevator it recommended that I set my Elevator to 1" up/down on full rate and 3/4" up/down on Dual rate and my Rudder to 1 3/4" right and left on Full rate and 1" left and right on Dual rate. Now just so you'll know I have a 9C futaba radio so maybe you guys can tell me what I need to set it on. I really don't mean to sound so stupid but I really need to understand this part of the hobby, now what I have been doing in the past is just setting the rates up just off the top of my head, for example I would only use two different rates only on the ailerons , The rate by default on my 9C would be a of 100 and I would change that to 75 and my expo to about -30 and the for my high rates or 3D or what ever its called I would set it to 120 and expo of -50 and I would use my C toggle switch to go back and forth to those settings, Now don't ask me why I set it to those that's just what I have figured out on my own, But I want to learn this the right way, so could someone please spend a little time and fix my rate hell I'm going through....
Thanks a lot
Randy
