The Roo is a great flyer. There is only one characteristic you need to watch for. If you get it too slow inverted, it will go into a flat spin. I have seen several guys spin into the ground because they didn't know how to recover. Just get the nose down, which means up elevator, and be SURE to reduce power to idle. If you use power to try to fly out of it you will spin to the ground. If you use full power, you might even CHICKEN FLOP!
Dennis Lott
