RE: Pacific Models <span class=
Make sure you have enough room for the cooling air to enter and exit the cowl. Then make sure you aren't running too lean on the needle valve. Open it up til you can hear it slow down some then close it til the speed just picks back up and smoothes out. That wil be a little on the rich side but it should run OK there.
