RE: maybe a chance to start
Well its not a bad buy just cant use it here if its not in the AMA Doc but over were you are it should be fine to use. the only down fall is that it is old technology and to up grade it you will probably be in for the same amout as a new one so your choice, it will work for your application. Also keep in mind there will be a load to carry to the field to start this turbine.
