RE: UCD issues
Dang,
Im hurt ............. I think my U CAN DO is beautiful!
Another thing on those wheel pants. You will see in the instructions that you need to drill a couple of holes on each side through the landong gear and into the wooden block for small wood screws. These guys wear out fast. I took the screws out, epoxied the pants to the landing gear and then worked epoxy into the screw holes and screwed those babies right into it. Those succers wont waller a loose' anymore! Just be neat with the epoxy, let it partailly set so it wont run and if you do it right you cant even tell its there....
