RCU Forums - View Single Post - Best Pattern Plane
Old 12-03-2003 | 12:09 AM
Troy Newman
Default RE: Best Pattern Plane
Piedmont Models makes them both
http://www.piedmontmodels.com/
They are good solid planes. They are both the same size roughly 2M even though the trend is to go with short wings. Both models have the same wing on them. Basically just different construction and a little different look. They both fly very similar. I know what the website says about 9 3/4lb Focus 2's for the prototypes. I don't think that will prove out in the end I would suspect the F2 to be heavier than this perhaps in the 10.25-10.5lb range. Remember the prototypes are always a little lighter and built of the very best wood hand picked. Production models will probably a little heavier...Most of the Focus 1's were 10.5 to pushing 11lb or over 11lb. I think the guys worked very hard to get the weight down. To their credit I'm sure some of it came off but I would doubt a 9.75lb F2
Now I have seen the Temptation flying at below 10lbs so it is possible for sure with that model...A realistic number that is great for the Temptation is around 10-10.25lbs.
These are simple to operate models that have the properties of the top end high dollar pattern models. They basically evolutions of older designs that have been very successful. I have flown both the Temptation and a F1 with many of the F2 mods on it....They are honest airplanes.
They are not the top of the line top 10 in the world level models but then again 99% of those flying are not at this level of competition. They don't have all the sexy looks and top notch trick stuff inside but they fly well. And can be trimmed and setup to where they will out fly your skills for many many years to come.
By the way I'm not Sponsored by them and I'm not flying their airplanes...I have flown other peoples models including my Father inlaw owns a F1 with the F2 mods on it. I would recommend these models to anyone flying AMA pattern. When you get to the requirements of the newer FAI (international) sequences the requirements change a little. But this is only at the top skill levels and at that level you are competing with the best flyers in the world...Personal Preferences really take over!
Troy
