It would look like the front tires are missing, and the front frame section was bent. But it would look pretty cool right before the wall. If you gear it a little higher and run it on road only you can get probably 55 or so out of it with the stock engine. I think dual .21's may be a bit over kill though. For serious power, I am sure you could almost squeeze a .25 in it. Then it would be flipping over any time you touched the throttle.
