RCU Forums - View Single Post - Piccolo question
Old 12-04-2003 | 07:09 AM
VinceHerman's Avatar
VinceHerman
Default RE: Piccolo question
Mike, you have the same transitter as tomflier. Help me out. My CHP has the exact same innards, except that the the ratched spring is flat rather than with a nub on the end like yours, right? We weren't sure if we should bend the spring or replace it with a flat spring. I wonder if that heli version spring is something you can order.
On the switch to change HH usage on the same model, "not me". I am fairly confident that I would choose the wrong switch setting and piroutte my heli into oblivion. So I have two models. Piccolo and PiccNoHH. This way I know before I power up my bird that I have the proper settings. Manual page 77? You mean these things come with a manual? That's what I have YOU for! :-)
tomflier, I guess I need to do more research on the CP setup used by the picc pro. Eventually I want to get there, and as always, I want to do a year of research before I make a decision.
