ORIGINAL: Isphius
just a correction, the blackfoot has plastic bushings, there is no metal bearings at all. The plastic ones are not even worth thinking about, so buy bearings. The bushings last about 2 runs before the hole is bored out and chipped up by the shafts they ride on. The extreme is just the next generation.im not sure what they did though. I have the ultimate blackfoot though
I beg to differ, The King Blackfoot came out with a Steel Bearing set that was included in the kit. That was one of the main differences between that and the Super Blackfoot. That and the fact that they went away from the single body post on the hood and went with the more conventional 2 pins on the front hood, and they went with a fleetside body for the first time. Now they are still using the fleetside body but they have also added a neet little hoodscoop to the truck.
