RE: How Refreshing
If I screwed it up then I will have to get another model and try again. Dbow
[/quote]
You seem have a good attitude about how it goes with models, so what is keeping you from building it the way it came. Very light! You really will be suprized on what little material it takes to make something work. My GP Cap was my test bed, if I had used a lighter engine it would of been under 4lbs and it is a 60 size plane! I could not break it, parts did not fly off, full throttle snaps, blenders and walls did not phase it.
Everyone want to build like, "this is what I did before," or "that can't be strong enough". I'm glad the Wright Brothers didn't have that mind frame.
I'm not being negative, just trying to expand ones thinking.
BTW: You probably won't want to be around when I fire up my 27lb, 41% Edge. Heh heh
