RE: How Refreshing
Darrinc,
I welcome the advice, that is the other reason that I started this thread. I am learning a lot from all of you, however I do not think that anyone needs to have a bad attitude to make a point. I am not speaking about you Darrin but another that posted on this thread.
I weighed the plane and all of the parts just a few minutes ago, it came in under 5 lbs, it is hard to be real accurate with my fishing scale but it looks like 4-3/4. I did not weigh the remaining screws and so forth but there is not much weight there.
I do also have a heavier battery pack in the plane right now so when I actually put the one for this plane in there it will loose a little there.
Per everyone's advice here I will not add anything more to the plane, I was planning to beef up the area under the gear and a couple other places but I will leave it as it is.
Dbow
