Help with a color scheme
Oh boy, oh boy, OH BOY! Now the fun starts!
Ok, Here's what to do:
Set your rudder throws to MAXIMUM. That is, have the rudder deflect so much that it is almost touching the elevator.
Now, get ALTITUDE!
Once you are waaaaaaayyyy up there, pull back on the stick to get almost inverted, then... Push both sticks toward the antenna (Full throttle, Full Right Rudder, Full Down elevator, Full Left aileron)
It should flaten out after about 3 revolutions. If not, re check your CG. To pull out, just release the sticks.
But remember! Pull out early! The plane is COMPLETELY stalled, and will need to go nose down for a while to regain flying speed. After you've done a few, you'll get the hang of how much altitude you need to recover.
ENJOY!
