RCU Forums - View Single Post - Help with a color scheme
Old 09-09-2002 | 06:35 PM
SilverEagle2
My Feedback: (9)
Default I am curious?
The manual for this bibe states a couple things that I am wondering if you guys followed.
Rudder:
D 8. Draw a centerline all around the edges of the
rudder. Sand the rudder to a taper as shown on
the fuselage top view. The framework should
end up approximately 3/32" thick at the trailing
edge.
Refer to the centerline you drew to keep the
rudder symmetrical.
Are any of you tapering this as th instructions say?
Elevators:
D 9 Using a sanding block and coarse (80-grit)
sandpaper, sand both sides of the elevators to a
taper (see cross section on plans) The trailing
edge should end up approximately 3/32" wide
Are you doing this as well, or are you sheeting without tapering and then just rounding off the edges.
Thanks for the help!
Here is the full manual incase you are wondering
