RE: Tail Sagging In Turns?
Sounds like adverse yaw, caused by the outside aileron dropping too low creating too much drag. The cure is what they call differential ailerons; set up the ailerons so they go up more than they go down, probably about a 2:1 ratio. When using one aileron servo, use a wheel or six-arm output arm on the servo and move both pushrod attachment points forward so they are no longer straight across from each other...JIM
