RCU Forums - View Single Post - Moki 210 Idle adjustment disk
Old 12-05-2003 | 01:22 PM
tonyc's Avatar
tonyc
Default RE: Moki 210 Idle adjustment disk
The O rings is what holds the idle disk in place. Mine is so tight that the idle disk turns with great difficulty.
Your O rings may be worn or perhaps too small. You should replace the O rings. Your Moki will not run correctly if the idle disk keeps moving.
Horizon hobbies has Moki parts and should have the O rings.
Hope this helps
tonyc
