RCU Forums - View Single Post - Tail Sagging In Turns?
Old 12-05-2003 | 09:35 PM
michpittsman
Default RE: Tail Sagging In Turns?
rik756-When the pushrod attach points are both forward, the up aileron will go further up than the down aileron will go down, regardless of which way you are turning. Differential is most often used to advantage on flat bottom wings...JIM
