Servo Glitching
I have two airplanes, I am experiencing the same problem in both. When under load, one channel glitches. Example, in my Pitts, if I move the rudder, the aileron servos glitch. In my decathlon, if I move the elevator, the rudder glitches. I thought it could be a low battery, due to a load being placed, but I fully charged, then tried again. The servos are GWS, not impressed with these servos yet, but will they also cause the glitch? I have the antenna wire running under the plane and straight to the back. I walk a little distance away, extend antenna, retract antenna, no change. Help, its pissing me off!!! [:@]
