RCU Forums - View Single Post - setup of 3d aerofly pro
Old 12-08-2003 | 09:19 PM
Kanain's Avatar
Kanain
Default RE: setup of 3d aerofly pro
sputknik,
I fly AFP primarily with my Fut 9C and sometimes with my 8U Super. Depending on the control surface, I usually start out with 25-30 Expo. I don't like it to soft around the middle, but I have a light touch anyway - a lot of years flying pattern. The only time I "bang the corners" is entry into some RADICAL 3D.
If I'm cycling batteries, I use my RF G2 Interlink (USB) and have AFP setup with both TX and Joystick (Interlink) for two plane action. You can setup the joystick setting in AFP somewhat and I use about 35% Expo then because the the Interlink is pretty tight.
Hope this helps.
