setup of 3d aerofly pro
NF, CANADA
Hi I just got afp a few day ago,"AWESOME".Just wondering which model to use,seems like the bretling is best but the hype 3d seems to respond alitte better but more sensitive and doesn't hang as well.Looking at the expo setup but don't know what numbers work best.Any pros out there who got this conquered.Replies would be appreciate.Any tips as mater a fact. Sputknik
hi.
glad you like AFP
The CAP BRIETLING is the most realistic, i havent bothered with mukin about with expo. the hype i find isnt ver realistic
glad you like AFP
NF, CANADA
Thanks for the reply.I haven't actually flow 3d yet but over the last couple of days I got the hover down pretty good.Don't know if its goin to actually be the same as in the field or not.I can get out of almost every bad situation now.I was wondering what percent u would give to the program with respect to 3d vs reality.....looking forward to ur reply.
If you add wind, add a little thermal and turn up the turbulance a bit it will give you a realistic hover.
Can i ask what plane you will atempt to hover, but dont toit close and either do i HIGH or a foot of the ground.
with a no wind ectc setup is give it a 50-75% realism
Depends totally on what plane you are flying. If you are flying a big extra or Cap, then yes it is probably pretty realistic. It is really hard to get the big extra and cap to fly like a 50 size model such as the Capiche 50. I have been tying to modify the Cap to get it to fly similar. It takes time and is very tricky.
While it may not be 100% real, it helps you learn the inputs for torque rolls and harrier rolls.
NF, CANADA
Hey there "edible" I got the ultrastick40,with a k&b 61,also got extra 300 ,68"modified with a st90 on that.Its a cg model.I think i got the funtana for my birthday tommorrow,"fingers crossed"no engine yet for that one
NF, CANADA
Hi there luke 3d.Let me know what ur settings are ,i assume ur using afp.Also what are ur tublence and wind speed set on...thanks in advance.At present i can hover the hype, cap, and giles for 15-20 sec without drifting too much.Have to try the wind and turblence.
NJ
I run aerofly off my 9C I have alot of expo set up but that is a matter of prefrence.
work on hovering the hyper 3d its harder to do but when you get that down it it will make other (and real) planes easier.
I need to mess with the settings of the hype.. i think with a touch more rearward CG it might make it handle better.
the hype is a horrible thing to fly unless you just want to pi$$ about.
happy birthday for tommorow sputknik[&:] hope you get the funtana. try out the 3D (if you dont already hang about there) forum, everyone on there will help you set up you planes for 3D
NF, CANADA
Thanks edible.Yes i got the funtana,nice bird.Don't looks as fragile as they say.Got to get an engine now,can't wait till next year though.Any way i will continue this conversation on 3d page.
sputknik,
I fly AFP primarily with my Fut 9C and sometimes with my 8U Super. Depending on the control surface, I usually start out with 25-30 Expo. I don't like it to soft around the middle, but I have a light touch anyway - a lot of years flying pattern. The only time I "bang the corners" is entry into some RADICAL 3D.
If I'm cycling batteries, I use my RF G2 Interlink (USB) and have AFP setup with both TX and Joystick (Interlink) for two plane action. You can setup the joystick setting in AFP somewhat and I use about 35% Expo then because the the Interlink is pretty tight.
Hope this helps.
Hope this helps.
For those of you using this with a 9C radio, how are you hooking it up? I was told by Ikarus it wouldn't connect to a 9C but he thought there were adapters available somewhere. I'd like to get this ordered for Christmas. Thanks.
Moderator
My Feedback: (58)
ORIGINAL: I & C Tech
http://www.rcuniverse.com/forum/m_10...tm.htm#1059139
My Feedback: (62)
NJ
Rajul, Merry Christmas to you too
Anyone that is flying the add on Extra 330S, in the CG set up screen, there are three entries? What the heck do they mean?
Is there a help file to explain some of the editable options for aerofly? Thanks_bob
Anyone that is flying the add on Extra 330S, in the CG set up screen, there are three entries? What the heck do they mean?Is there a help file to explain some of the editable options for aerofly? Thanks_bob
