RCU Forums - View Single Post - Are there different ways to set up Dual elevators w/o y harnesses?
Old 12-09-2003 | 09:16 AM
LancelowDowell
Default RE: Are there different ways to set up Dual elevators w/o y harnesses?
You just have to watch out with the 6xas. They use the elevator dual rate switch to control the pmix on and off... so you will most likely loose the dual rates on the elevator to set that up.
