ORIGINAL: unknown
lov2flyrc
Take a closer look at your engine spec, from the 21# to 28# any one of these engine same 12 burner same (Garnet two size compressors) only RPM make the different and tail cone.
Unknown,
Simply not true! While some are very much alike, others are very much different. AMT is completely different engine from a Jetcat. Jetcat is completely different from a BMT....... NOT ALL are the same, some run and are very reliable while others create boxes of blown parts like you have in your garage. Just because some are similar in design does not make the "The Same"
or equal for that matter.
Todd
