Hovering
OK I'll check the lateral ballance, I assume I just hang it from the center of the spinner to the tip of the tail and see which wing is heavy. I can move my 6 volt battery pack one way or the other, hopefully to the right. I've got the rudder servo set at max throw, It's the standard Jr servo horn. I'll need to get a larger aftermarket horn. any ideas? I think dubro makes some plastic ones. anyway, this will get me more throw.I think the rudder has about 2 1//2 inches of throw right now, does this sound adaquate? well, it that doesn't do it, i'll put some right thrust in, but then my cowling won't line up perfectly.....UGGGGGG
John
If your not a dream, your a nightmare
clear the prop!
