Hovering
I'll use dual rates to add as much throw as I can on the ailerons, and I'll try spoilerons also. I hadn't considered using the elevators as ailerons, I'll try that if nothing else works.
Will messing around with the thrust line not help much at all? Should I not even bother?
Tuomo - Do you mean that going with a lower pitch prop ( 15x4 instead of 15x6 ) will help with the torque problem?
