RCU Forums - View Single Post - CA Debonder won't get CA or Epoxy off!
Old 12-15-2003 | 04:57 PM
FLYBOY's Avatar
FLYBOY
Default RE: CA Debonder won't get CA or Epoxy off!
If you are trying to get something off that is epoxied on, you can use your heat gun to loosen it, but if it is balsa coated with epoxy, you are screwed. A lot of heat will loosen a part glued with epoxy so you can get it off. Don't burn the wood.
