 CA Debonder won't get CA or Epoxy off! >
Old 12-15-2003 | 04:43 PM
Yub, yub, cmdr!'s Avatar
Default CA Debonder won't get CA or Epoxy off!
I got some Pacer Zap CA debonder.
I can't get that CA off the unsheeted wing!! I tried rubbing it. I tried lightly sanding it with a file, I even tried picking at it with a pin.
It just won't go. I also have fuse CA and Epoxy problems.
Big Problems.
How do I do it right?
Thanx!
PS Let's wait till CArl Wright invents us some non-dripping CA!
Old 12-15-2003 | 04:51 PM
DustOffUH1's Avatar
Default RE: CA Debonder won't get CA or Epoxy off!
I don't know how to get epoxy off (except sanding), but Acetone works great for removing CA glue. I had a speed controller switch that I accidentaly got CA glue on. Could't move the switch to save my life. I soaked it in Acetone overnight and the switch is as good as new. I never tried it on a balsa wing yet, so I don't know if the acetone would have any bad effects on the balsa. I would try a test piece first.
Joe
Old 12-15-2003 | 04:57 PM
FLYBOY's Avatar
If you are trying to get something off that is epoxied on, you can use your heat gun to loosen it, but if it is balsa coated with epoxy, you are screwed. A lot of heat will loosen a part glued with epoxy so you can get it off. Don't burn the wood.
Old 12-15-2003 | 05:01 PM
It's covering coated with a drop of Epoxy.
I have CA Debonder, will this work for CA? (Well, it is called CA Debonder)
Old 12-15-2003 | 05:09 PM
FLYBOY's Avatar
The epoxy should just peel off covering. CA on covering is a little harder, but try the debonder, and if that doesn't work, try acetone. I use that to clean it after I cover a plane to take any marks off from covering.
Old 12-15-2003 | 05:21 PM
Epoxy peel off da covering? way cool!
Where can u buy Acetone in small bottles?
Spags (only in MA) has the Huge Bottles of Watery Acetone for like $15.
Anyway, Y doesn't debonder work? I mean, it's called debonder! (Odd why people call it debonder. Why not call it Unreliable Gelatinous Thingy?)
Old 12-15-2003 | 05:26 PM
Me again. You need to leave the debonder on a long time and let it soak through the dried CA.
Old 12-15-2003 | 05:37 PM
Mindwarp's Avatar
ORIGINAL: Mike Ledbetter
And use it liberally, and multiple times.
Just like the shampoo bottles say "Rinse and repeat as necessary."
Old 12-15-2003 | 05:57 PM
Depending on just how bad the situation is, it might be easiler to peel off a small bit of covering and put on a patch. Just a thought.
Old 12-15-2003 | 06:21 PM
FLYBOY's Avatar
ORIGINAL: Montague
Or just leave the glue on the covering and not worry about it. It won't hurt anything in the air.
Old 12-15-2003 | 08:51 PM
Really?
Whoppee
BUT
ALL the beep glue is now beeping purple!!!!!! The beeping debonder is beeping purple!!!
AAAHHHH!!!
(I think I need a Cub Yellow and White Ultracote trim sheet and a nice nap.)
Old 12-16-2003 | 12:07 AM
Hey David!
Don't worry about it. The way it looks won't affect the way it flys. (As long as it's reasonably straight.)
If you look close at the planes I fly, you'll see a few spots of CA or epoxy on them too.
Dennis-
Old 12-16-2003 | 09:00 AM
most of the debonder I've used is acetone in a different package and was always clear,sounds like you have a pvc cleaner solvent.
Old 12-16-2003 | 11:45 AM
aww dang.
it's ppurple. It is Pacer Z-7 or something CA debonder, I bought it at Hog Heaven Hobbies.
DB : :-) O well.
But it's purple!!! AAHHH!!! I'm probably gonna buy some Cub Yellow and White ultracote trim sheets.
