RE: ROO II Question
You can use heat gun and a credit card to slightly lift the hinge pocket, heat the area lightly (dont get it too hot) and slide the credit card between the elevon and the trailing wing skin and push the elevon up. Hold it there till the surface cools and then move down the wing the width of the card and do it again till youv'e covered the span of the wing. This will correct the gap....
Todd
