RE: Symthoms of being alergic to CA glue??
Hi SNOWWAVE! If your eyes itch, that is an early warning sign. Your reactions can get worse with repeated exposure. Believe it or not, TITEBOND glue can get the job done better, if you don't goop globs of it on it will dry pretty fast, and the price is right. A handy building board is a sheet of styrofoam with waxed paper taped over the plans, a light spray of 3M77 adhesive on the wax paper helps hold the parts in place [you might be allergic to that too]. T-pins push into the foam easily and hold things together, and masking tape holds things also. Pour the tightbond glue into a dixie cup and use a tooth pick to dab it on.
