What do I do now?????
Mine balanced with no lead.I use an Enya .50cx way out on the mounts with the battery behind the fuel tank.
I built mine as a trike and not a tail dragger. What did you do on yours? What kind of balance stand are you using? When the tank is empty on mine the tail does fall to the ground but the CG is at the back of the range.
later daveo
