RE: Symthoms of being alergic to CA glue??
Simple solution when I use CA (if you don't have windows) I use a small fan set at the lowest setting about six feet away from me.
CA is quite potent, I used to get nose bleeds while sleeping. At first I could'nt understand why. Later I realized that whenever I had used thin CA I had nose bleeds. For glues I use Weldbond and Lepages Carpenter's glue, they both tack quickly. They do the job just as good as CA without the health hazard. I use minimal CA, and when I do I use the fan technique..............try it.
Garthwood
