RE: Help!!!!
could it be your clutch? i read an artcle that said if the clutch spring were weak the clucth engages before the engine can get into its power band and the result is that the engine bogs when the clutch engages and it makes the engine seem like it is running rich when it is not. i may be wrong but check that angle out and maybe thats your problem. good luck and how did you get to me a moderator?
