RCU Forums - View Single Post - What do you do with a dead Yard Bee?
Old 12-24-2003 | 12:16 PM
Hanger-Flyer's Avatar
Hanger-Flyer
Default RE: What do you do with a dead Yard Bee?
uhm....how about "Bambi"?
I've used other wings on that Dandy fuselage too. That old beat up fuse has turned into a sort of "lab animal" where I try out different stuff. It's tougher than nails and tolerates hard landings thanks to my "industrial strength" landing gear scheme.
Experimenting is fun, and it helps me learn more about model planes and their flying personalities.
Here's a couple of pics of the fuselage with other wings and the same Dandy fuselage. The Mini Piper wing is very stable, but not very "lifty" so the power needs to be cranked up for straight and level flight.
The Mini Telemaster wing has almost too much lift, and the plane is a little hard to manage in the air, but landings are feathery. The control surfaces are a little small for that bigger wing. The real Telemaster fuselage mates really well with its own wing because the Tele has a much larger tail.
I've come to see that fuselage with 2.5 inches (wide or high) works best for me to accomodate my Kokam batteries. Which would be better in your opinion, 2.5 inches wide, or 2.5 inches high? Which would fly the best?
ID:	84951   Click image for larger version
