In that case you'll have to use a scoop or a louver like you have, that way the vacuum created by the exaust tube will draw air over the cylinder head, it should work fine and not present any issuses if the opening is suffecent and the duct work is right.[:-] " YOU CAN DO ANYTHING YOU WANT, IT JUST DEPENDS ON HOW MUCH OF AN ANIMAL YOU ARE! "
