RCU Forums - View Single Post - Help, plane wants to roll when looping
Old 05-20-2002 | 04:57 AM
DGrant's Avatar
DGrant
Default Help, plane wants to roll when looping
Start with some stick-ons first. Clean area real well, and apply accordingly. Do this before you cut. Test fly with the stickys, and after that install them. The Zen has fiberglass tips too, so a small cut in the underside just inside of the tip would be undetectable. Then you can glue the weight to the outermost rib. Good luck.
