RCU Forums - View Single Post - Flapperons Eclipse 7 question
Old 12-27-2003 | 04:04 AM
Wolfpack's Avatar
Wolfpack
Default Flapperons Eclipse 7 question
I will be tryign to set up flapperons on an eclipse. I just got this radio and I will be running duel ailerons on the airplane. I was told that if you did this that you would loose the ability to trim one of the ailerons, is this true? They said I would have to put the other aileron on say channel 7 and then I would not be aboe to trim it. How do you set up flaperons properly with this radio? can you use flapperons with a y harness? what is the best way? thanks!
