RCU Forums - View Single Post - Capiche 50
Thread: Capiche 50
Old 12-27-2003 | 05:56 AM
  #2125
Archie
Default RE: Capiche 50
Edible
With all due respect I see you are not one for READING INSTRUCTIONS ![8D]
If you look at Phillys drawing, which is not necessary because you will see it quite clearly shown on your plan, you will note that the degree of chamfer you have applied is wrong. You are trying to make the inside edges of the back of the fuz paralell to take the fin post. with the angles you have its not parallel it is...or anything like the drawing.
Read the instructions and study the plan for the bit you are doing. If you had done this I would not have got the question about the M3 pushrod kit from you in my pm box... this pack comes with exact instructions. !! Now be a good lad and spent 30 mins browsing the instructions and the plans and you should not be able to go wrong.
I might have expected this from an adult who has had too much Christmas cheer but I figured you would still be abstaining at this stage !
Xmas went well this end but guess what - I didnt get a Capiche for Xmas... I was hoping for the 140 !
Good luck Ian......
