RE: Servos for Rappy 30?
Thanks Guys:
I was not quite sure what to do about the stiff links, and I was just going to run it gently until it loosened up a bit. I think I will take basmntdweller's advice and look into loosening them up a little first. This is my third heli, but the only one that was this stiff to start off with. With the links a little less stiff, the servos might just be o.k. for cruising around and hovering.
I will still keep an eye out for a good deal on the servos you gentleman have suggested. Thanks again.
