RE: GMS 1.20 on UCD .60
I am not familiar with this model. I do not use ARF's. But my feeling would be that it is way too much. I feel with that engine balancing the plane will be difficult. That is significantly more weight than the plane was designed for. Also that much power will be hard on the airframe. It is a lightweight frame for 3-D work. I would suggest a Morris Hobbies Balsa Nova 120. That engine would be perfect for that kit. It is a kit but should not be too hard to build. There are some import arfs in the pattern and 3-D section here that may be of some help. I do not pay too much attention to them as I build all of my planes myself. Good luck whichever way you go.
Mark Shuman
