RCU Forums - View Single Post - Flapperons Eclipse 7 question
Old 12-28-2003 | 12:37 AM
3DFanatic
Default RE: Flapperons Eclipse 7 question
Plug one aileron into channel 1 and the other into channel 6. Go into the Eclipse's FLPN mix and activate it and set the rate for each aileron individually. THen set the rate for your spoilerons/flaperons. The flap/spoilerons will be on you Ch6 knob (left side of case).
It is impossible to do with when using a Y-harness.
