RCU Forums - View Single Post - Flapperons Eclipse 7 question
Old 12-28-2003 | 03:46 AM
Wolfpack's Avatar
Wolfpack
Default RE: Flapperons Eclipse 7 question
OK, the reasons for the quesitons is because I have been talking with a friend and he was concerned about the trims, but he has now sent me this email:
Found it. No apparent problem with flaperon... it's when attempting to use
dual elevator servos. You can't use a simple "Y" harness because one needs
to be reversed. You can buy an inline reverser, but with the computer
radio, you SHOULD be able to slave a spare channel off of the elevator
channel only reversed. In this situation, it's not a pre-programmed mix
like elevon/flaperon, so the trim only affects one elevator panel.
RCD's suggestion was to trim the slave with the flap knob, and said that
they would be fixing the software in the future. Message was dated
07/20/2002, so our radios probably are not "fixed".
Soooo, any comments on how to set this up witht he eclipse 7 radio? Does he have it right, or is he missing something and making this duel elevator servo setup too complicated? What is the best way to set up the duel elevator servo with the eclipse? THanks ! ! ! !
