RCU Forums - View Single Post - TACHOMETERS...
Old 12-28-2003 | 04:27 AM
Lee Belew
Default RE: TACHOMETERS...
My second dislike of the TNC Tachometer.
2. The off/on switch is a slide switch. If a person forgets to turn the switch off it will eventually run the battery down.
Note: The battery is not an alkiline. I upgraded the battery while I had the unit apart.
I replaced the slide switch with a push button switch. Now all I must do is make sure that I do not stack something on top of the tach and turn the switch on and run the battery down.
Many of you will say that I have voided the warranty by making these changes. And yes I am aware of that however why should I use a device that does not fit my needs. Besides I am an Electronic Technician and can make these changes without fear of damaging the Tach. The switch on the left is the off/on switch.
I will post some photos of the tach with the push button switch tomorrow.
Here are the photos with the push button added. Plus a side view.
Go flying and have a good time.
Lee
ID:	85656   Click image for larger version
ID:	85657   Click image for larger version
ID:	85658   Click image for larger version
