RCU Forums - View Single Post - Proper 3D Setup
Old 12-28-2003 | 01:53 PM
MikeEast's Avatar
MikeEast
Default RE: Proper 3D Setup
Hey Chip,
I have a Futbaba 9C. On my U CAN DO .60 I have a problem with the endpoint adjustment between high and low rates on my elevator surfaces. Whenever I setup endpoints to match up the elevator travel on low rates, the high rate ep throws dont match up. In other words, at full throw low rates the end point of travel matches up perfectly, but when I switch to high rates and give full up or down the sufaces may be as much as 1/4" off. Most of the misaligment occurs at that last, say,, 10degrees of throw.
Question,
Do you know if the 9C has the ability to set up different endpoints on different rates? If it does I cant find it.
If it doesnt, is there something mechanically that I may have out of square? I have done all I know to do and I cant figure it out.
My quick solution has been to get the endpoints adjusted out on high rate and then just live with it on low rates since I seldom use full up or down elevator on low rates.
Im hoping that I have something mechanically setup wrong that will correct this.
Mike
